Any difference between brands?
Solved by Fasauceome,
7 minutes ago, Darkharry said:asus turbo, asus rog or zotac
Asus' Turbo is their base model, with a blower style cooler and a basic copper heat sink. The ROG, on the other hand, is one of their high end models, with multiple fans and a nice vapor chamber.
Zotac has a pretty wide range of offerings, but their budget options are ones I have more experience with, and generally they have some pretty good cooling performance.
Ever since a few generations ago, Nvidia has a feature called "GPU boost" which is enabled by default. The better the cooling on the graphics card, the more performance you will get with automatic boost speeds. A GTX 1080 with a good cooler should automatically be boosting over 1800MHz. Often close to 2000MHz
