Pcie to Sata speed for NAS
Solved by Owsleygarcia95,
I'm not 100% positive, but more than likely that is s pcie 3x1 card giving you a 1GB/s theoretical maximum throughput. Unless you're using obscenely expensive/fast enterprise drives, you should be good to use all 4 without it slowing down. 2 will be fine.
Featured Topics
Winterlight ·
Posted in Phones and Tablets0 -
2
ineedhelp.2145 ·
Posted in General Discussion0 -
atxcyclist ·
Posted in Home Theater Equipment1 -
3
ElChales ·
Posted in New Builds and Planning4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
