first ever build :)
Go to solution Solved by PC HEROES,
1 hour ago, daxooly said:
Budget (including currency): £800
Country: England
Games, programs or workloads that it will be used for: sea of thieves, rocket league, fortnite
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): already got a 2060 super and some ram wondering if everything else is fine.
https://uk.pcpartpicker.com/list/WPfrt7
Hello... I was looking over your list and I made some changes that will greatly improve your performance. I was also able to give you a brand new GPU as well, it's much faster and newer than the RTX 2060 Super 8GB. I found you the AMD Radeon RX 6650 XT 8GB. It will allow your games to be much faster, smoother, and look a lot better. I was able to get you 32GB of RAM and a new PC Case that will Maximize your Airflow and I added 5 more Fans to improve the Airflow even more. 3 Fans Added to the top and 2 Fans for the top of the PSU Shroud to help Cool the GPU. Your Temps should not be over 70 degrees even under full load. I threw in a CPU Cooler too because the Stock AMD Cooler is good but now the CPU can Auto Overclock and not worry about the Temps.
Let me know what you think and feel free to ask any questions you might have.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://uk.pcpartpicker.com/list/bWRsjH
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (£120.00 @ Amazon UK)
CPU Cooler: Thermalright Assassin King SE ARGB 66.17 CFM CPU Cooler  (£26.00 @ Computer Orbit)
Motherboard: Gigabyte B550 AORUS ELITE V2 ATX AM4 Motherboard  (£108.48 @ Amazon UK)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£60.00 @ Amazon UK)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£101.59 @ Amazon UK)
Video Card: MSI GAMING X Radeon RX 6650 XT 8 GB Video Card  (£239.99 @ AWD-IT)
Case: Montech AIR 903 MAX ATX Mid Tower Case  (£59.99 @ Scan.co.uk)
Power Supply: Corsair RM650 (2023) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (£74.99 @ Corsair UK)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fans 5-Pack  (£19.99 @ AWD-IT)
Total: £811.03
Country: England
https://linustechtips.com/topic/1551620-first-ever-build/
Country: England
Not a bad build at all!
All parts will fit and the PSU is a very solid and reliable unit, it will be with you for a while and 750w is plenty of power if you plan on upgrading to more powerful parts later.
Will be a great 1080p gaming machine 🙂
Awesome! 👍
https://linustechtips.com/topic/1551620-first-ever-build/#findComment-16275264
It looks fine. I personally don't like the chassis or its price tag for a budget build, but that's up to you. Also I would suggest you look for used prices on those parts except for maybe the NVMe. all of those or better are available for used. I don't see much point buying any of these parts brand new.
https://linustechtips.com/topic/1551620-first-ever-build/#findComment-16275273
Country: England
Total: £811.03
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1551620-first-ever-build/#findComment-16275310
