Hey,
Before I start, this is all going to sound really stupid, but I just need to check on this.
I feel like I don't know if I put the case panel on the right away for this cooler master case. I'm not really tech savy, and was just trying to clean the case when I found the bottom two screws wouldn't screw properly no matter what and there are small gaps that I'm just suspicious of. Can someone tell me if I put it on correctly?
Thanks
https://linustechtips.com/topic/1551404-need-help-with-panel/
3 minutes ago, Azzazy698 said:
Hey,
Thanks
Like it hasn't screwed in the whole way? Try turning it around clockwise 90 degrees 4 times if it's a square and only once 180 degrees if it's not
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1551404-need-help-with-panel/#findComment-16273826
