What would happen if i plug Display port 2.1 into a Display port 1.4 monitor
Solved by Guest,
There will be no benefit to using a 2.1 cable, no. It will work at the spec that both ports support which will be 1.4.
Featured Topics
Tamgam12 ·
Posted in New Builds and Planning6 -
remo233 ·
Posted in New Builds and Planning19 -
5
6
10
rickymohk ·
Posted in General Discussion3 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5
