First time building a custom pc
1 minute ago, Newbie80085 said:So should I switch to a B650 motherboard?
And how much read and write speed should I look for before buying a M.2 ssd?
And can you suggest a good PSU under 6000 rupees ( around $80 US) ?
I'm not familiar enough with the A620 motherboard to know.
Differences in NVMe speeds don't have a significant impact on gaming. While a drive with hardware cache is preferable, pretty much any NVMe drive would be acceptable.
I'm not familiar with the Indian market. Nor any local PSU brands.
PSU is the single component that can literally destroy all others. It directly affects system stability and longevity. https://cultists.network/140/psu-tier-list/ is a useful resource when looking at PSU. Tier A or B would be ideal, Tier C would be okay. Anything lower would be a poor choice.
