Hi so I can't take a picture right now but I'll explain as well as I can.
My CPU, GPU, and one of my two top case fans are on. The other top case fan and the two front fans are off. I only just started to notice this when I was testing some stuff in ASUS Fan Xpert. I know I didn't turn them off but anyone got any idea why it's doing it? I checked and they are all plugged in.
Specs below.
Corsair 230T Black with red LEDs • AMD FX-8350 4.0GHz 8-Core • Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler  Asus M5A99X EVO R2.0 ATX AM3+  Kingston HyperX Genesis 8GB (2 x 4GB) Kingston HyperX Fury 8GB (2 x4GB)  NVIDIA GeForce GTX 1060 6GB • Corsair RM 650W • Windows 10 • Logitech G403 + G810 • Audio Technica ATH-TAD300 • 1TB Seagate HDD x 2 256GB SanDisk SSD
https://linustechtips.com/topic/155049-fans-not-on/
you probably made it so they dont spin unless the temp goes up or something.
I'm gonna launch ArmA 3 for a bit and see if anything happens, I'll report back.
https://linustechtips.com/topic/155049-fans-not-on/#findComment-2066859
Are they connected to 3 pin fan headers? If that's your case regulating it's speed is a bit more complicated, below a % they may stop
Some fans don't undervolt well and may need a certain amount of voltage to start spinning.
https://linustechtips.com/topic/155049-fans-not-on/#findComment-2066932
Okay I just turned it off and unplugged all the fans and re-plugged them and it was fine. thanks!
https://linustechtips.com/topic/155049-fans-not-on/#findComment-2067051
