problem with air link connection
Definitely not normal. I don't know anything about that particular router, but you may be able to troubleshoot it a bit (settings, location, etc) or a better router should help. Are you using the 5Ghz band?
5800X3D | RTX 4070 | 32GB RAM | 1TB NVME (boot) | 2TB NVME (storage) | B550M DS3H | Samsung S90F 65" OLED | Denon x1700h 5.1 Surround Sound
i'm using the 5 ghz band with 80mhz of bandwidth, the reception is perfect and i have ethernet on my pc
