Hi
This may not be in the right section, if not could you please advise where I should post it.
With iCloud prices keep going up.
I was looking for a way to replace iCloud.
I would like something that when the little people get home they can sync there iPhones. Preferably wireless. To backup any pictures or documents.
I have a spare pc but it's only 6th gen or I have a pi 4 with 4gb ram, that I can use.
Any help will be much appreciated.
Thanks
Steve
https://linustechtips.com/topic/1549314-icloud-replacement/
I use NextCloud for everything - iPhones, iPads, Androids and Desktops, sync documents, photos, Joplin and many other tasks on HP ML 310, but I think that Intel 6th generation or Pi 4 be capable, I recommend give a try to NextCloud... And this be your computer with your data.
ad infinitum
https://linustechtips.com/topic/1549314-icloud-replacement/#findComment-16260815
