RAM XMP Problem
Solved by RONOTHAN##,
Just now, FireLegend said:How do I even overclock CAS Latency? Like would I have to increase/ decrease anything else or just the cl16? Sorry I'm an overclocking noob on these things.
You should just need to edit the timing in the proper menu. 3200 CL16 is not aggressive enough to require doing anything else, though in theory you might need to raise the memory voltage at the same time. Just run a memory stress test after doing this and I'd call it good.
