Is your network adapter properly showing up in Device Manager? Screenshots are ideal.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1548747-ethernet-not-working/#findComment-16257058
3 minutes ago, jig said:
Both are showing up properly & both are updated.image.png.8b0855aeff678f22ee5e39ef3b09f25e.png
They are both disabled. (you have two, for some reason)
https://linustechtips.com/topic/1548747-ethernet-not-working/#findComment-16257071
I know they're disabled, if I have them enabled my wifi will not work thus I wouldn't be able to post here. Enabling them causes the issue I provided, and yes I have disabled my wifi when enabling it. I have 2 as I have 2 ports, I've tried both ports, both do not function. I have tried different ports on my router as well
https://linustechtips.com/topic/1548747-ethernet-not-working/#findComment-16257075
