Hello im looking to build a new pc and im pretty confused about gpu
For the cpu im going with a ryzen 7 5700x and im looking for a gpu between 200-300$us
I wanna play mainly gtav doom eternal cs:2 fortnite and some racing sims(i have a wheel)
Please help me im really not sure what is my best option and if im better off with a used gpu or a new one
Thanks
https://linustechtips.com/topic/1548120-need-a-help-chosing-a-gpu/
Thanks
what resolution are you playing at
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
Thanks
Used is better value for the price, but brand new comes with warranty and stuff.
For brand new, $300 will could get an RX 6650 XT
https://pcpartpicker.com/product/z9H7YJ/powercolor-fighter-radeon-rx-6650-xt-8-gb-video-card-axrx-6650xt-8gbd6-3dh
Or an RTX 3060
https://pcpartpicker.com/product/sM8bt6/zotac-geforce-rtx-3060-12-gb-gaming-twin-edge-oc-video-card-zt-a30600h-10m
Primary PC:
PSU tier list
How many watts do I need?
I don't know why but many sim games including many racing games gobble up 3D cache. If you're gonna be playing racing games might be worth it to invest into a 5800X3D. I know in ACC and iRacing the 3D chips get a disproportionate lead in fps compared to other CPU's.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Or an RTX 3060
But is the 6650 better. Also does the 7600 or 6700 also worth considering
Cause i saw both of them around my pris range
Also the rtx 4060 isnt that much more expensive does it worth the diffrence.
This is such a hard choise
There's a pretty small difference in performance between the 6650XT and the 6700. Both are a bit faster than the 3060
The 4060 wouldn't be a bad option, it launched at too high of a price but it bevame a bit cheaper recently. It's slightly faster than a 3060 also.
If you want to see the performance numbers, have a look at reviews on YouTube, Gamers nexus is a good example
Primary PC:
PSU tier list
Depends on how far apart they are in price. Directly proportional. 7600 lets say is 10% faster than 6600 but also 10% more expensive. Get which ever one is best value for money with a direct calculation.
4060 is redundant. Only consider 4070 or up for gaming only.
1440
