6 minutes ago, Reez12 said:
my gpu stops spinning when I go on one game but it spins when I go on amd app
What GPU do you have?
Most modern GPU's have something called ZeroFan mode, the fans will not spin if they are under 60-65c ( depending on the card ). This is to reduce fan noise and fan wear 🙂
If you check your GPU temperatures and everything is okay then you have nothing to worry about.
https://linustechtips.com/topic/1548073-help/#findComment-16252576
I fixed it I had to turn off sum
https://linustechtips.com/topic/1548073-help/#findComment-16252578
