I got a AMD Ryzen 5 3600X 6-Core Processor 3.80 GHz, 16GB of Ram, NVIDIA GeForce RTX 2060, SAMSUNG SSD 981 512GB, 1TB HDD, Case: Kolink Inspire K7 with 1 fan in the rear back and 1 CPU cooler.
When I play games like ovewatch 2 I get around 110fps mid fight, fortnite around 90fps mid fight but on rocket league I get around 380 fps and I play on the lowest graphic setting on every game and my Graphic Card has around 77 degrees while playing games.  I haven't replaced my CPU thermal paste in like 2 years but I do clean my Pc every 3 weeks or so. I just look for some advice on anything really to get my fps around the 165 area, or preferably more. And if this is the wrong Topic sorry.
https://linustechtips.com/topic/1547996-help-with-my-pc/
Thats just the difference in a per game basis, some games can achieve vastly more fps than others
But if youre looking to up FPS regardless
Temps?
Overclock CPU?
Overclock GPU?
Ram speed?
Ram in dual channel?
Background processes?
Any actively running apps while playing games?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1547996-help-with-my-pc/#findComment-16251942
On the slightly lower side but similar to what I was getting with 2700X and 5600XT.
Run a 3DMark benchmark to see if you're within spec of others.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1547996-help-with-my-pc/#findComment-16252036
