As the title suggests, which card would suit my scenario the best.  Firstly, I am using an NZXT H440 case, with moderately adequate cooling, and there is more than enough room for the actual card.  I am looking specifically at the EVGA Superclock GTX 780 with ACX.  How would this cards cooling really differ from the blower type cooling in the reference? And because my case is smaller, would it be smart to choose the blower cooling rather than disperse heat into my other components?
Project Insomnia
CPU: Intel i5 4670K @ 4.6 GHz.   CPU Cooler: NZXT Kraken x40   Motherboard: ASRock Z97 Extreme6   Memory: Corsair Vengeance 8Gb.   Graphics Card: EVGA SC Geforce GTX 780 Ti   Power Supply: EVGA G2 850W   Case: NZXT H440
https://linustechtips.com/topic/154776-reference-gtx-780-vs-non-reference/
My ACX 780 heats my 4770 on an H100i to around 50°C when the GPU ONLY is folding and i have a 750D. Its up to you, i would pick the ACX anyways just because i like those Mhz
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
How impossible would it be get the extra Mhz. by overclocking a reference card?  Also, wouldn't blowing the heat to the back of the case be more beneficial?
Project Insomnia
Uh not at all i think Linus got like a high 13ØØMhz range or maybe 14ØØMhz range on his reference card. idk you can check his OC doc. You CAN get very good reference cards its just more LIKELY that you will get an OKAY to GREAT card when you buy non-reference. idk what you mean by that last sentence but my SouthBridge "Chipset" gets really hot when my GPU is going. Doesnt hurt it but i still dont like it.
I would go with a ACX card. If you really want a blower style i believe the PCB is actually the same layout so you could buy a reference cooler on eBay for $30 and slap it on there
| F@H STATS |
Upon further investigation, I fell across the Galaxy GTX 780 HOF.  What do you think of that card?
Project Insomnia
Cant find it for sale anywhere but cool. Looks like it had good reviews
| F@H STATS |
That card is absolutely worthless at $699. You might as well buy a 780ti.
Back to the original question...ACX cooler is fantastic for keeping things cool and relatively quiet. It's not going to give you more or less overclocking ability than reference cooler though.
It helps is very small form factor builds, like an itx build. But for regular mid tower builds, the open style coolers are more ideal. They cool a little better but spill that hot air into the case. Those bigger cases can have more, bigger fans, so the more hot air becomes a non-issue.
Well, I'd recommend you get the acx cooler if you're going to go like 1 way, and then the reference cooler if you're going to be either water-cooling or doing a sli solution. But then again it's a personal preference, if you don't mind the slightly increased in temps with sli.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
