A few years ago I bought a samsung display, with which has for the most part served me well. Now a year ago I started to get some weird stripes on the bottom of the display. But only after turning the display on and they would disappear after a few minutes. Sometimes it's better and sometimes it's worse. I have tried diffrent cables (HMDI and DP) with diffrent PCs and reset the settings of the display multiple times. But I always got a similar graphical error. I was wondering if anyone might know what the issue is.
Monitor: Samsung C32JG5x
https://linustechtips.com/topic/1546701-problem-with-my-display/
This is most likely a loose connection inside the monitor, from the LCD panel to the controller board.
If you feel comfortable with electronics, you could open it up and disconnect and reconnect the display.
Qoute my reply if you want me to answer back.
