Cpu for 4070ti
11 minutes ago, OnyxLeigion said:I had a 4070ti kind of fall into my lap, I'm wondering if there's a cpu that'll work with my current mobo(MSI b450 Gaming Plus) that'll attempt to keep up, or if I should just shell out for a new mobo/cpu/ram package. At that point I'd probably just bite the bullet and build the whole PC.
聽
Current build is a r5 3600, 4x8GB ddr4(base speed is 3000, I oc'd it and dont remember the speed I settled at), Corsair rm850x.
聽
Not currently asking for budget advice or anything, just if there's a reasonable upgrade in my current system to match the 4070ti or not.
Update the BIOS and buy a 5800X3D
聽 The 5800X3D keeps up extremely well with even the latest CPU's and is a perfect match for the 4070ti.
聽
I would guess you will be gaming at 1440p 144hz and that would be a nice setup indeed.
聽
If you want to spend a little money then the 7800X3D + B650 motherboard would be the next step up from the 5800X3D in my opinion. You would also need new DDR5 RAM.
