The motherboard doesn't use standard power connectors.
The case has space for a weird L-shaped PSU.
Sorry, unless you want a dangling power supply with spliced cables. I recommend sticking to the OEM.
Qoute my reply if you want me to answer back.
https://linustechtips.com/topic/1546002-power-supply-sixe/#findComment-16239404
Not necessarily. Most OEM pinouts have an adapter available somewhere on the internet. Something like this may work
https://www.moddiy.com/products/HP-Compaq-Elite-8300-CMT-PSU-Main-Power-24-Pin-to-6-Pin-Adapter-Cable.html
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1546002-power-supply-sixe/#findComment-16239412
11 hours ago, --SID-- said:
This is the PSU. It's as proprietary as proprietary can be. As far as I can find there is only a 240w model but since only low profile GPUs fit in the case 240w model is plenty.
If you had the measurements of it you could probably find a sff psu that would work. Another option might be taking the disk reader out and putting it there
Main Gaming Machine
https://linustechtips.com/topic/1546002-power-supply-sixe/#findComment-16239915
