Aorus Z790 Extreme X not registering Wifi via antenna or ethernet connection
Solved by What's a GPU?,
After typing this out it occurred to me that you can use CMD to bypass the internet requirement for windows install. After doing that and running the driver update it resolved the issue. Hopefully this helps someone else!
Featured Topics
mbecker ·
Posted in Peripherals0 -
Prajnaanicca ·
Posted in CPUs, Motherboards, and Memory2 -
2
ZGruk ·
Posted in New Builds and Planning2 -
Cramig88 ·
Posted in Networking0 -
7
Xnihilo97 ·
