CPU Overheating Damage
Go to solution Solved by Fasauceome,
17 minutes ago, iGPR3 said:
How much damage will this have done to the CPU, if any?
minimal damage, because thermal throttle is designed to protect the CPU from thermal damage. It's better that the PC was shutting down, because it was basically hitting the emergency brakes.
My friend’s i7-4790K has been thermal throttling like crazy for the past month or so. Yesterday he told me his PC had been shutting down randomly for a while, so we checked HWinfo and it was consistently over 90*, even at idle. I had a look at his PC and one of the corners of his CPU cooler mount had snapped, so it wasnt making contact properly.
How much damage will this have done to the CPU, if any? And will this affect the performance? Thanks.
https://linustechtips.com/topic/1544835-cpu-overheating-damage/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1544835-cpu-overheating-damage/#findComment-16230677
