Kind of what I would expect on the Wraith Stealth depending on factors like case airflow.
As long as it's not throttling I wouldn't worry too much about it.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
22 minutes ago, cwark18 said:
Recently Bought a Ryzen 5 5600x and i'm using it with the stock cooler, but while i'm gaming the temperature is around 80-90 degrees is this normal or do i need to change something. it had preapplied thermal paste and the case is from a aqvin prebuilt that i'm upgrading.
The stock is kinda meh and the 5 5600x is a hot cpu , you should be fine however in Amd's site it says max temp is 95 so if it stays for  short periods on 90-95degrees you should be good.Id advise you to use a aftermarket air cooler tho.
An aftermarket cooler is a great idea, especially for a cooler like this. I'm a little late to this post, but I have some recommendations for good cpu coolers. I personally use the Be Quiet! Pure Rock Slim 2 in my system, and it's a great cooler. It fits in a lot of smaller cases, and it cools my 12600k just fine. Another good option is the Cooler Master Hyper 212. It's not as small as the Pure Rock Slim 2, but it's still a great cooler. The mounting mechanism isn't the greatest, but it'll do the job.
| Mark Solutions as Solutions | Just Because Nobody's Replied Doesn't Mean Nobody's Thinking | Refresh Often| Bottleneck Calculators are BS|
Main System: CPU: Intel Core i5-12600K/ COOLER: Be Quiet! Pure Rock Slim 2/ RAM: 32GB (2x 16GB) Corsair Vengeance LPX DDR4 3600MHz/ GPU: MSI RTX 3070 LHR Ventus 2x OC/ SSD1: 512GB NVMe M.2 SSD & SSD2: SK Hynix P41 2TB/ Case: Fractal Pop! Air (Black RGB TG Clear Tint)/ PSU: EVGA SuperNOVA 750 P2/ MOBO: AsRock Z690 Phantom Gaming 4
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-67 C (140-152.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 71-74 C (161.6-178.4 F)
Second System: CPU: Intel Core i7-4960x/ COOLER: Old Corsair 120mm AIO/ RAM: 32GB (4x 8GB) Corsair Vengeance DDR3 1600MHz/ GPU: AMD Radeon PRO W5700 GPU/ SSD: 250GB Samsung SATA SSD & HDD: WD Blue 500GB/ Case: Thermaltake Level 10 GTS/ PSU: Corsair RM1000X
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-65 C
GPU: Under Fur Mark for 45 minutes, temps reach around 69-73 C (156.2-163.4 F)
Laptop: Lenovo IdeaPad Gaming 3i 15IMH05 (Intel Core i5-10300H, 16GB DDR4 2933MHz, Nvidia GeForce GTX 1650 Ti, 500GB NVMe M.2 SSD & 500GB SATA SSD)
Temps under load: CPU: Under Cinebench r20 looped for 30 minutes, temps reach around 87-92 C (188.6-197.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 81-84 C (177.8-183.2 F)
NAS: I converted an older Advantech PC used for X-Ray machines to hold a hard drive or two. CPU: i7-6700 with whatever cooler was in the Advantech chassis/ RAM: 32GB Generic DDR4-2666/ SSD: Samsung 250GB SATA SSD/ HDD: 2TB Seagate random HDD
Phone: iPhone SE 2 (2020 version)
