Hello,
I had a pc with ryzen 5 2500x and 1060 3gb on asus prime a320m-k motherboard and I wanted to update it so I can play some newer games but failed in doing so.I bought ryzen 5 5500 and rx 6600 pulse and when I have put it on my asus a320m-k pc wouldnt post,I didnt update bios and for some reason gpu fans werent spinning so I put my old stuff in (5 2500x and 1060 3gb)and pc still didnt want to post even with old components but it used to before any of this and I do not know what to do now?
I checked all the cables,ram and everything..help!
Thank you in advance!
https://linustechtips.com/topic/1543066-pc-components-problem/
Dumb question first - did you flip the power on the psu back on? If so…
Put the old stuff back in if it’s not already. Make sure everything is seated in well. Unplug wall power and press the start button for 10 seconds to clear capacitors. Clear the CMOS with the button or shorting the pins (see mobo manual for location of button/pins). Replug wall power, make sure psu is on, and try to start.
If it works, make sure you get the right bios for your board to support the new cpu.
Good luck.
https://linustechtips.com/topic/1543066-pc-components-problem/#findComment-16219839
