is there much difference
Go to solution Solved by flibberdipper,
by transfer speed what does that mean? better fps? and yea i love the look of the board too
Think of it like this (and this may not happen in real life with your system, but it's a good reference).
You have a 16 lane highway, and everyone is happily going along at 70 MPH. Then more traffic comes in and it goes down to an 8 lane highway, and everyone slows down to 45 MPH.
is there much difference between PCI x16 and PCI x8. i want to no because my MOBO has 2x 16 slots but my GPUs will be so close together so will there be a fps hit if i was to space them out and one will be in PCI x16 and another in PCI x8
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/
You'll be running them in the two light brown slots anyway, both 16x.
yea i no that is what is recommended but my 280xs will be so close together if i run 1st card in the top slot and the 2nd card in the last slot which is 8 x will there be a difference in FPS?
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057536
Do you have a picture with them in the two light brown slots? I thought there would be plenty of room.
I ran two 270x's on a asus m5 99fx pro r2.0 and they had a good inch between the cards.
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057547
Transfer speeds. That's pretty much it.
Also, I love the way the Sabertooth and TUF boards look. So sexy.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057579
i only have one at the moment because the other on is in the mail but just looking at it looks like there will not be much room.
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057582
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057586
Ahhh yeah, those sapphire cards are nearly triple slot, the MSI one are dual.
Put em under water :P
Sorry, I'm no help.
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057626
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057633
Sorry, I'm no help.
i did order a msi one should i put that in the first slot.
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057638
Yep, should give you plenty of room for that fat assed sapphire :P
lol thanks for all of your help one last thing if i plug a screen in to the 2nd gpu will it still work as normal?
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057668
That I don't know, I've never played with eyefinity, but I'm pretty sure you might need all your monitors plugged into one gpu.
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057691
ok thanks again
PC PART PICKER
https://linustechtips.com/topic/154293-is-there-much-difference/#findComment-2057699
