1 minute ago, nice2mitchyou said:
Help me choose a processor that fits or that is compatible with my gpu, also can someone suggest a good budget aircooler with it as well!
I currently have,
ryzen 5 3600
rtx 3050
16gb ram
650watt psu
What’s your budget, use case and country? Try and use the template that’s given to you when you make a topic
also what specific model of 650w psu?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Budget (including currency): around $300
Country: Philippines
Games, programs or workloads that it will be used for: CS2 & Valorant, and editing with after effects and premiere pro
Other details
ryzen 5 3600
rtx 3050
16gb ram
650watt psu gigabyte 80+ bronze
hoping to get 240+ fps on cs2 and similar games
Just now, KostakisXDDS said:
As you have an rtx 3050 I mean it is not the best gaming card out there. I would suggest for you to take a better graphics card than cpu. But tell me your budget and ill tell u 😜
I can workaround $300-500 for cpu and gpu
Other details
ryzen 5 3600
rtx 3050
16gb ram
A 5600 and a Thermalright PA120 or ag/ak620 if you really want to buy an air cooler but the 5600 comes with a stock cooler. Then a 6700 xt is about 300 so that should be in budget l
Total: £1040.95
