hello everyone!
i've been experiencing heavy battery drain on my xps 15 9510 for a while now, even though i have the "bigger" battery this model supports, i cannot get more than 3 hours away from the wall no matter the occasion.
im aware that my oled 4k display consumes more power than a normal panel, but to this extent??
for example i manually put the laptop to sleep and closed it for 20 mins, which resulted in a 10% battery drain, which is unreasonable, given that i have to shut it down every time i put it in my backpack, or it boils itself alive while killing the battery
i should mention that even though the dell app shows my battery health as "excellent", hwinfo64 shows my battery as about 25% degraded which shouldn't be normal after a year of use(imo)
also, i did not reinstall windows when i got it, but i did make sure to kill any unwanted startup processes
looking forward to your insight!
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1540979-laptop-battery-drain/
after a lil bit of searching, my laptop has modern standby enabled and when i run powercfg /a under s3 sleep it says:
        The system firmware does not support this standby state.
        This standby state is disabled when S0 low power idle is supported.
so , is there anything i can do?
https://linustechtips.com/topic/1540979-laptop-battery-drain/#findComment-16207008
8 hours ago, NavyCobra1417 said:
Regarding sleep battery drain, I'd change all sleep functionality to hibernate instead.
i've done so but hibernate isnt really a replacemeny for s3 sleep
https://linustechtips.com/topic/1540979-laptop-battery-drain/#findComment-16207525
