Hello, first build
Go to solution Solved by brob,
PCPartPicker Part List
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor ($407.43 @ Amazon)
CPU Cooler: Deepcool AG620 WH ARGB 67.88 CFM CPU Cooler ($59.99 @ Amazon)
Motherboard: MSI PRO Z790-A MAX WIFI ATX LGA1700 Motherboard ($259.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory ($99.99 @ Newegg)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($119.99 @ Amazon)
Video Card: Asus DUAL OC GeForce RTX 4070 12 GB Video Card ($592.14 @ Amazon)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case ($89.00 @ Newegg Sellers)
Power Supply: Phanteks AMP v2 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($154.99 @ Newegg)
Monitor: Asus TUF Gaming VG27AQ 27.0" 2560 x 1440 165 Hz Monitor ($283.99 @ Amazon)
Total: $2067.51
Generated by PCPartPicker 2023-11-14 17:55 EST-0500
Hi, I'm trying to see what parts can be recommended to me for a PC. A monitor can be included in with the price.
Budget (including currency):  2500 usd
Country: United States
Games, programs or workloads that it will be used for: games I play/would like to play: starfield, cyberpunk, valorant, apex, alan wake 2
I also use adobe programs such as photoshop, illustrator, after effects, and blender for modeling/rendering.
Other details: I want to play at 1440p and have a white build. I do like the Corsair 5000d airflow for a case, but I'm open to other options. I'm interested in an AM5 build, but I hear intel may be better for Adobe programs.
Other than that, I'm open to any suggestions, and advice for this build
Thanks!
https://linustechtips.com/topic/1540806-hello-first-build/
Thanks!
Think that'll fit the bill 🙂
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  ($307.99 @ Amazon)
CPU Cooler: Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  ($47.99 @ Newegg)
Memory: G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory  ($199.99 @ Amazon)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($146.00 @ Amazon)
Video Card: Gigabyte EAGLE OC GeForce RTX 4080 16 GB Video Card  ($1059.99 @ Best Buy)
Case: Phanteks ECLIPSE G500A DRGB ATX Mid Tower Case  ($124.99 @ Newegg)
Power Supply: Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($154.99 @ Newegg)
Monitor: Gigabyte M27Q 27.0" 2560 x 1440 170 Hz Monitor  ($269.99 @ Amazon)
Total: $2571.92
Generated by PCPartPicker 2023-11-14 17:38 EST-0500
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16205804
Total: $2067.51
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16205815
Total: $2067.51
thank you
and if I wanted to go with an aio, what size would you recommend for this case?
Lastly, I'm interested in Corsair's icue/link system. I know it's adding to the amount, but if I wanted to do something like that what size fans should I get?
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16205875
3 minutes ago, abc123_g said:
thank you
Use a 360 AIO if you must. 🙂
I'm not a fan of the iCUE system, but if you want to tightly tie yourself to Corsair products, check the pricing of the 5000D RGB Airflow. Couple it with an H150i AIO. No need to buy more fans unless you want more bling. In which case use Corsair RGB 120mm models.
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16205888
CPU: *Intel Core i7-13700 2.1 GHz 16-Core Processor  ($387.99 @ Amazon)
CPU Cooler: *Deepcool AG620 WH ARGB 67.88 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($159.99 @ Amazon)
Memory: *G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  ($194.99 @ Newegg)
Storage: *Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.99 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti 12 GB Video Card  ($781.64 @ Newegg)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($89.00 @ Newegg Sellers)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($121.98 @ Other World Computing)
Monitor: *Acer Nitro XV1 XV271U 27.0" 2560 x 1440 180 Hz Monitor  ($209.99 @ Amazon)
Total: $2220.55
Generated by PCPartPicker 2023-11-14 21:53 EST-0500
A better look at those components.
https://store.acer.com/en-us/27-nitro-xv1-gaming-monitor-xv271u-m3bmiiprx
https://lian-li.com/product/lancool-216/
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/us/en/products/sku/230490/intel-core-i713700-processor-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-WH-ARGB-Dual-Tower-CPU-Cooler-1700-AM5/2022/16083.shtml
https://www.gskill.com/product/165/377/1649234605/F5-6000J3040G32GX2-RS5K-F5-6000J3040G32GA2-RS5K
https://www.crucial.com/ssd/p5-plus/CT2000P5PSSD8
https://www.gigabyte.com/Graphics-Card/GV-N407TWF3OC-12GD#kf
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16205889
thanks again!
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16205898
Total: $2067.51
$2500 budget for a 1440P gaming build that includes using Adobe and Blender and the best you could come up with is a 4070 and 32GB of RAM? Some of your builds are decent but not that one.
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16206005
There is lots of room in the budget if OP wants more GPU. I just don't think it's necessary for 1440p.
Posting graphs that have offer no context is pointless.
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16206028
The graph says it all.  If I told someone that I had a $2500 budget and that I wanted to game at 1440P and they suggested a 4070 I would be like 'wth'.
https://linustechtips.com/topic/1540806-hello-first-build/#findComment-16206036
