So I'm looking to buy new case fans for my corsair 500r. I recently bought two cougar fans but they're way too loud for me. So I was wondering which Noctua fans I should get for my case. I know the NF-s12a is a great case fan but there are other fans that I could also get. I really need silenced optimized fans. Any help would be appreciated. My budget is around $120.
https://linustechtips.com/topic/154069-case-fan-help/
To be clear it's just for airflow not being mounthed on a radiator? @ThatOneGuyThatOnlyPlaysPC noctua is bringing out a redux series which will be more cost effective for consumers. erm.. be quiet sells good fans.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/154069-case-fan-help/#findComment-2054773
Noiseblocker E-Loops, and Scythe Gentle Typhoons are great alternatives for Noctua fans, otherwise any airflow optimized Noctuas (I think they have an F in the product code somewhere) like NF-F12s are a fantastic option for quiet fans  :)
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/154069-case-fan-help/#findComment-2054802
Scythe gentle typhoons and noiseblocker E-loops are the only fans that are on par with noctua's.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/154069-case-fan-help/#findComment-2054936
