Please Help With Throttle Stop
18 hours ago, Shimejii said:its 4.2-4.4ghz on a single core
An 11400F can use the 44 multiplier when 1 core is active and this decreases to the 42 multiplier when all cores are active.
18 hours ago, Shimejii said:the 11400f is a pretty locked down CPU
The turbo ratios are locked down. The MSR and MMIO turbo power limits are not locked. I would check the MMIO Lock box and I would set PL1 to 154W which is the same as PL2.
PL1 set to the default 65W value causes power limit throttling. If a person cannot find or if power limit control is not available in the BIOS then ThrottleStop can be used to get maximum performance out of an 11400F.
14 hours ago, Electronics Wizardy said:Your clocks are in line with the multi core boost speeds they list
The TechPowerUp review confirms that when you increase the 65W power limit like they did, the 11400F runs faster. That is what @Dailo needs to do if he wants his 11400F to run games at 4200 MHz instead of 3600 MHz to 3800 MHz.
