Desk help
Go to solution Solved by jaslion,
Course why not. Just mount the monitor arm to the metal bar with the clamp and for cable rack get one that isn't a solid block but can fit around the metal bar or inbetween.
My current desk is an office desk, and there's metal beams covering under the desk spanning 4CM Long 2CM Thick, Would it be possible to still get a dual monitor stand and a cable rack?
My desks dimensions are 160CM Length x 85CM Width.
The  metal supports are welded together and I cannot remove them.
Thanks
https://linustechtips.com/topic/1539796-desk-help/
I just wasn't so sure because of how small the beams are, Do you have any recommendations on a cable rack like that? I've looked but the only ones I've found are crazy expensive (200+).
https://linustechtips.com/topic/1539796-desk-help/#findComment-16197939
An ikea cable collector.
or like this stuff
https://www.amazon.com/Under-Cable-Management-Organizers-Organizer/dp/B09L62NFJ2/ref=sr_1_8?crid=3UJ9FLD4GLXZE&keywords=cable+management+desk&qid=1699392672&sprefix=cable+management+desk%2Caps%2C174&sr=8-8
https://linustechtips.com/topic/1539796-desk-help/#findComment-16197946
