http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=27567387
So, I hope the link above works. :\
Anyways, I'm assuming you mean USD?  For $1000.00, that wishlist is probably what I would go with if you were needing all your peripherals, monitor, OS, etc.  The AMD FX-6300 and -6350 and great budget gaming CPUs and overclockable.  The monitor is only 21 inches but it's 1080p AND you can upgrade it in the future.  Basically there is a good path in this build to be able to upgrade your components in the future as you can afford it if you so desire.
Anyways, hope this helped.
"The doctors X-rayed my head and found nothing."  - Dizzy Dean
i7-4770K, ASUS Z87 Gryphon, EVGA GTX 780 Ti, 16 GB Kingston Fury RAM, Crucial M500 240 GB, 1TB Seagate Barracuda, Cooler Master Hyper 212 Evo, Seasonic 760W PSU, Asus BD, Phanteks Evlolv mATX (Gunmetal).
https://linustechtips.com/topic/15390-first-build-budget-build/#findComment-172657
Something like this: http://gyazo.com/2e4e2610be102adf86a66ba8e08daa75
 with these: http://www.amazon.com/Logitech-X-240-2-1-Speakers-Black/dp/B000MDZWUS
I have these speakers. Despite their price, their better than a lot of $50 speakers.
This^^^ and pick a case to put everything in.
https://linustechtips.com/topic/15390-first-build-budget-build/#findComment-183589
