6650XT best bang/buck for low-mid?
In terms of price to performance, the RX 6650XT is the best value card right now on the market - bar none. There actually isn't a better card in terms of cost per frame available from AMD, Nvidia, or Intel.
Here's the chart from Hardware Unboxed's RX 7600 review:
If you take the current prices of any other card, and compare it to the $220 of the RX 6650XT, you'll see that they all fall short.
In terms of Intel cards, the Intel Arc A580 is slower than even the RX 6600. The A750 is the same price, while also being slower than the 6650XT - the A770 is the card that trades blows with the 6650XT.
So your assessment is accurate. The RX 6650XT is the best bang for the buck card on the market right now - at least as far as non-used cards are concerned. And I also agree that it would be a decent pairing with an i5 10600K.
If you need the pull the trigger right now, and value for money is the most important thing for you, then it's probably the way to go.
