people coming for the same problem can watch my video
specs:
intel xeon 2643 v3
ddr4 motherboard
ddr4 16gb ram 2133mhz
gtx 970
500w psu
read my last post for context but yeah i keep going into psm
i recorded my gpu fluctuations tell me if anythings irregular that could cause this
(it only happens with roblox)
Edited by tenstall
correction
https://linustechtips.com/topic/1538672-help-with-power-saving-mode-solved/
that is super strange NGL. You could attempt to turn off any power saving options and making sure windows if you're running windows doesn't go into sleep mode VIA an admin command prompt
https://community.spiceworks.com/topic/2223812-is-there-a-command-line-to-disable-sleep-on-windows-10
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
ive fr tryed everything ill try this though
also maybe you're pressing a button that might been hotkeyed as "Sleep" perhaps? you can also change  "define power buttons and password protection" and change it so when you press a power or sleep button it does nothing .
of course you can still shut down your PC by holding down the power button cause that's a failsafe and normally within windows
nah cause i press alot of keys and it only happens playing roblox
i can run everything else valorant minecraft fortnite etc but roblox is iffy
anyways ive gone into theyre and its not that
yo that first thing worked for a little while then it kicked off again got any other ideas?
