Ram speed issue
Go to solution Solved by Skiiwee29,
Just now, Vellexar said:
Yep, thats whats expected. You're good to go. Ram is working as rated at 3200.
DDR stands for Double Data Rate
1600x2=3200
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1538304-ram-speed-issue/#findComment-16186576
2 minutes ago, Vellexar said:
I own some 3200 speed ddr4 corsair vengeance ram and in bios it says 3200 but in task manager it shows 1600. I am kinda confused and trying to play some tarkov but i am about to call it a day lol
Task Manager is sometimes weird but 1600 is correct, 1600x2 = 3200mhz
Nothing is wrong, continue gaming 🙂
https://linustechtips.com/topic/1538304-ram-speed-issue/#findComment-16186578
so it's just fine ?
Yep, working as expected.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1538304-ram-speed-issue/#findComment-16186580
Task Manager doesn't read frequencies correctly, especially on older hardware. What does something like CPU-Z say?
If CPU-Z says it's doing 1600MHz, then it's at the right speed because RAM is double data rate (the 1600MHz translates into 3200MT/s). Task Manager reads the data rate but says the frequency (usually, again it's pretty frequently just wrong).
https://linustechtips.com/topic/1538304-ram-speed-issue/#findComment-16186581
posted cpu z
https://linustechtips.com/topic/1538304-ram-speed-issue/#findComment-16186587
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1538304-ram-speed-issue/#findComment-16186588
