I have been getting this error for the last few months and every time I get this error, the screen goes black and comes back and then the programs crash. I have uninstalled and reinstalled the drivers with the DDU program and it didn't fix it. Even if I close every application running in the background and just open the game, I still get this error. The error usually happens 20-30 minutes after I open the game. Even if I turn on debug mode via NVIDIA control panel, I still have the same problem. I would appreciate if you can help me what to do.
My PC Specs:
Asus ROG RTX 3080 10 GB
AMD Ryzen 5800x3D
ASUS ROG B550-XE Gaming Wifi
16x2 Corsair Vengance PRO RGB 3600 MHZ CL18
EVGA 750GA 80+ Gold
NZXT X52 Kraken 240mm
https://linustechtips.com/topic/1538278-dxgi_error_device_reset-error/
Error is pretty self explanatory in the screenshot you posted. I don’t know why you needed to fuck around with debug features as this is a pretty common thing to happen with unstable graphics cards. Monitor graphics card temperatures using a credible application like MSI afterburner or hwinfo. This also can happen due to unstable ram or cpu.
Considering you got Corsair rams, those would be a suspect too.
I use a Turkish interface, so you can tell me if you can't understand it, but I think you are Turkish as the name suggests.I played BF2042 for 30 minutes and my graphics card is running at a constant 65-66 degrees.
I normally use MSI Afterburner, but when playing BF2042, it won't allow the MSI Afterburner interface. So I used NVIDIA Overlay.
