Budget (including currency): $2,500
Country: Norway
Games, programs or workloads that it will be used for: Fps, rpg,
Other details
Hello everyone. I am in the market to build my first pc that will basically run any game and will last me a long time. But i am having a hard time finding parts so any help would really be appreciated.
https://linustechtips.com/topic/1538068-first-pc-build/
What resolution are you playing at?
Do you need a monitor, OS, other peripherals?
Do you intend to upgrade the PC during the life?
For your budget:
  • CPU: I'd be looking at 12th-14th gen i5 K or i7, or Ryzen 7700/7800X3D.
  • Graphics card: 7800 XT, 4070 or higher.
  • Memory/Storage 32GB and 2TB is fine for now, but if you're planning to keep it a very long time (e.g. 5+ years) then you could get 64GB and 4TB while RAM/SSDs are fairly cheap to buy.
  • PSU: 850 or higher to give you room for upgrades.
PCPartPicker Part List: https://no.pcpartpicker.com/list/KsMt34
CPU: Intel Core i7-13700F 2.1 GHz 16-Core Processor  (kr5014.00 @ Proshop)
CPU Cooler: Deepcool AK400 ZERO DARK 66.47 CFM CPU Cooler  (kr542.00 @ Proshop)
Motherboard: MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (kr2204.00 @ Proshop)
Memory: Crucial Pro 32 GB (2 x 16 GB) DDR5-5600 CL46 Memory  (kr1478.00 @ Proshop)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (kr1667.00 @ Proshop)
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card  (kr11043.00 @ CDON NO)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  (kr1218.00 @ Proshop)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr1799.00 @ NetOnNet)
Operating System: Microsoft Windows 11 Home Retail - Download 64-bit  (kr1815.00 @ Proshop)
Total: kr26780.00
Generated by PCPartPicker 2023-10-28 16:29 CEST+0200
https://linustechtips.com/topic/1538068-first-pc-build/#findComment-16184917
For your budget:
Total: kr26780.00
resolution: 1920x1080
And yes i am planning to upgrade it
https://linustechtips.com/topic/1538068-first-pc-build/#findComment-16184929
  • 2 weeks later...
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (kr2842.00 @ Proshop)
CPU Cooler: Xilence M705D CPU Cooler  (kr702.00 @ CDON NO)
Motherboard: MSI PRO Z790-A MAX WIFI ATX LGA1700 Motherboard  (kr3904.00 @ Proshop)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-7600 CL36 Memory  (kr2519.00 @ CDON NO)
Storage: Samsung 990 Pro w/Heatsink 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (kr2345.00 @ CDON NO)
Case: Zalman S3 ATX Mid Tower Case
Power Supply: Xilence XP1050MR9 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr1797.00 @ Proshop)
Case Fan: ARCTIC P12 Silent 24.1 CFM 120 mm Fan  (kr198.00 @ CDON NO)
Total: kr25746.00
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
https://linustechtips.com/topic/1538068-first-pc-build/#findComment-16199855
