Budget (including currency):  maximum £1400
Country: UK
Games, programs or workloads that it will be used for: Minecraft, CSGO2, Baldur’s Gate and web browsing and YouTube.
Other details: Current Part list (no peripherals needed but I need a monitor):
GPU: RX 7800XT
CPU: Ryzen 5 7600x
RAM: Crucial DDR5 CL46 5600mhz
CASE: Montech MX3
MOBO and PSU: need recommendations for my budget…
CPU COOLER: Deepcool AG400
MONITER: Need recommendations (a gaming monitor, 24inch curved and at least 150hz)
STORAGE: Crucial 3rd gen 1 tb
Any help for my build would be greatly appreciated!!! Thanks so much…
https://linustechtips.com/topic/1537159-my-first-build/
When are you planning to buy? If you don't need it right now, wait for the black Friday and cyber Monday sales that will be coming up soon
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1537159-my-first-build/#findComment-16177868
Seems pretty good. I've a few recomendations aniway, there is a web called PcPartPicker wich searches among most well knwon stores to find for u the best deals and also let u organaize ur build and it checks most compatibility issues. I've made a list with your components, with a few changes. Am5 platform works a lot better with low latency memory, if it fits in ur budget 6000Mhz CL30 if not 5600Mhz CL28, both of em are more or less same price so it just depends on where u find a best offer. There are really little curved +150Hz 24" monitors so i would stronly recomend u getting a flat one. Here i've made a list with my recomendations:
https://uk.pcpartpicker.com/list/3H68QP
It's the same CPU and a pretty apropiate and cheap cooler, same GPU and  same Case. I've chosen the cheaper (reliable brand) 1Tb ssd but that may change a lot depending on the day u look. I've put a CL30 memory, and about the mobo i've put a mATX (they are the sweetspot between the cost of fiting everything on a small form factor and the cost of the materials), it isn't the cheapest mobo but i've chosen this one because it has a B650 instead of an A520 chipset and has decent I/O with even an USB-C, althought if u want to really cheap out without downgrading CPU or GPU mobo could be a place to cut. On the PSU side i've chosen a more than sufficient wattage high efficiency Tier B power supply, wich is pretty cheap but if u can find them cheaper ALWAYS looking at PSU Tier List, the efficiency and if u can a review. On the monitor it's one of the cheapest 165Hz 1080p 24.5" and it's from ASUS so it's a pretty good deal. Right now the build would be at 1480£ so a little over budget, if prices don't go down for black fraiday i woul suggest changing CPU to an intel i5 wich can work with DDR4  or, what i'd probably do, sticking with AMD but last gen, also u maybe  prefer to continue with this one and cut on psu and mobo.
I'm sorry if i made any spelling mistakes, i'm not an English speaker.
Ryzen 7 5700G @ 4.2GHz All Core. Aorus Elite V2. 2x8Gb 3600MHz CL17. Nfortec Aegir X. Nfortec Nervia.
https://linustechtips.com/topic/1537159-my-first-build/#findComment-16177940
at 1080p you'll be very reliant on CPU performance. GPU performance less dependent. Let's guarantee no CPU bottleneck:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (£369.62 @ Amazon UK)
CPU Cooler: Thermalright Assassin King SE ARGB 66.17 CFM CPU Cooler  (£32.53 @ Amazon UK)
Motherboard: ASRock A620M Pro RS WiFi Micro ATX AM5 Motherboard  (£134.62 @ Amazon UK)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR5-5600 CL36 Memory  (£66.97 @ Amazon UK)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£49.81 @ Amazon UK)
Video Card: Sapphire PULSE Radeon RX 7700 XT 12 GB Video Card  (£436.06 @ Amazon UK)
Case: Thermaltake S100 Snow Edition MicroATX Mini Tower Case  (£45.96 @ Amazon UK)
Power Supply: Silverstone Essential 750 W 80+ Gold Certified ATX Power Supply  (£84.99 @ Amazon UK)
Monitor: ASRock PG27FF1A 27.0" 1920 x 1080 165 Hz Monitor  (£177.94 @ Amazon UK)
Total: £1398.50
Generated by PCPartPicker 2023-10-23 12:24 BST+0100
I hated curved monitors at such a small size a curved monitor is pointless. You're buying into the marketing. 32:9 or other extremely wide aspect ratios only benefit from being curved.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1537159-my-first-build/#findComment-16178536
Although it is now two generations old I would say the Intel 12600KF is still a good performer that is sufficiently powerful and future proof for your type of use case.
If I were to use RAM @8000 MHz (instead of @6000 MHz) and give the CPU an overclock I would actually match an i9-14900K @6000 MHz:
My advice is to choose the Intel 12600KF and pair it with RAM @7200 MHz or higher which is currently cheap.
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
https://linustechtips.com/topic/1537159-my-first-build/#findComment-16178564
For 97% of the people the 12600KF is redundant thank to the 13400F outside of severely budget capped builds where even 50 cents matter (cause 12600KF right now is $5 cheaper than the 13400F). A hotter, less efficient chip that 9/10 times is met with the 13400F in the exact same FPS.
I'd rather pay the $5 more on the 13400F and then save $20 on the lesser cooling it requires and then in the long-term save even more money on electricity not used.
Have a look
Dude is also mostly considering gaming where even an i9 get smoked by the 3D chips while using half the power and doesn't require insane watercooling.
https://linustechtips.com/topic/1537159-my-first-build/#findComment-16178627
