First pc build
Seems like a pretty good top of the line PC. I'd maybe choose a little bit higher psu but i's fine. Corsair and Seasonic has some 1200W models wich may be worth checking also if u wan't to go top of the line the Asus ROG THOT 1600T is pretty much the best u can get in terms of psu right now. Since it's AM5 it maybe performes even better with 6000MHz CL30 than 6400MHz CL32 (or maybe not i'm not sure, just something that u may want to check). About the time it's pretty good timing, DDR6 won't arrive until at least 2025, Pcie 6.0 isn't even created. Am5 will be continued for several years (if u were going intel i'd recomend u wait to 14Gen (althought is't gonna change so much) but since u are going AMD it's all fine). An the last thing is that i'd probably (knowing u have such a high budget) go with a little bit more reliable AIO and using a 980Pro or 990Pro insted of a 970Evo, this last suggestion will only give u a little bit more performance but i would do it...
