Is it compatible?
Go to solution Solved by Blackjack1336,
The Aio will not fit 13 gen without the mounting kit, but you can get it either free or inexpensive from Msi I don’t know how they deal with that but just google msi 13 gen bracket and you will find it.
the core liquid fits in the case no problem, would say mount it on the top for best thermals.
all products you named are Msi Products and SHOULD support mystic light. That being sad I personally don’t know the case and maybe it’s controlled with a cheap button changer thing I don’t know but I own a 360 version of the AIO and yes it supports mystic light.
Is the AIO Cooler: "MSI MAG CORELIQUID 240R" work with an Intel i5 13600K?
Also will the cooler fit into the case: "MSI MAG Forge 112R"
And does the cooler support Mystic Light?
Pure Laptop Gaming found here, gaming and video editing to be exact
Months of searching for the best and optimal gaming and video editing laptop
(I may sound dumb but that's part of the process, learning is good always)
By the scheme of the text color, I am Indian, with a budget
https://linustechtips.com/topic/1536820-is-it-compatible/
https://linustechtips.com/topic/1536820-is-it-compatible/#findComment-16175412
That AIO has clogging issue, it would fail very quickly. Even the V2 ones, as I read. I'd suggest Arctic Liquid Freezer II 240mm A-RGB.
Mystic Light is genuinely bad, IMO, I came from Aura Sync to Mystic Light, I was so disappointed by it.
But, to your question, as long as it is A-RGB, chances are, it will work with Mystic Light.
The case supports this config for AIO, so yes the case is compatible
  • Radiator Size Support
Front: 120 / 140 / 240 mm
Top: 120 / 240 mm
Rear: 120 mm
However, you need to account for the RAM/motherboard height for top mount, and the GPU length for the front mount.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1536820-is-it-compatible/#findComment-16175414
I own a 360 core liquid for over 2 years now and have no such problem 😕 but I heard a lot of that. Thought they might have fixed it by now
https://linustechtips.com/topic/1536820-is-it-compatible/#findComment-16175417
Well, there goes your 2 years worth of luck.
Kidding, they fixed it by recalling the V1s and releasing the V2s, yet people still find the same issue on some of them, so you might just got lucky.
I almost bought it myself, but after thorough research, that's what I found.
https://linustechtips.com/topic/1536820-is-it-compatible/#findComment-16175420
Thanks for the answer. But I'm planning to switch with a different plan now
https://linustechtips.com/topic/1536820-is-it-compatible/#findComment-16176263
