Gpu cable bend
Go to solution Solved by Dukesilver27-,
No one can say for certain, because the degree of the bend and how long it happens is too hard to estimate when or if there will be issues.
Now, resolution does not directly affect power draw, GPU usage and clock speed does. However, you always just change the power limit on the GPU with MSI Afterburner, it's easy to do, plenty of guides in youtube. Lower it as much as you could.
I'd just run the PC without side panel and pull the cable a bit so the bend would not be too much.
7 minutes ago, icetea7 said:
You guys think this is fine?
Is it a 12VHPWR cable? Then no. If it's a normal 6+2 pin or 8 pin I say yes just make sure it's plugged in all the way
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175349
Looks like 16 pin 12VHPWR, I wouldn't let it be like that, a lot of those things melt already, some testers said it was caused by the bend near the connector, and yours are very very bent.
Either get a bigger case, or vertical GPU mount, or get one of those cable mod 12VHPWR cables.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175351
I heard cablemod should be avoided....
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175373
Well, there were some cases where their cables have the issue as Nvidia's, but as I heard, they are less common than Nvidia's.
So at least there's that, correct me if I'm wrong tho.
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175378
Ok but meanwhile,are my chances of anything bad happening lower if i run everything in 1080? I would assume that power draw isn't that  big no? I don't have 4 k screen atm.
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175382
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175383
Ok thanks
https://linustechtips.com/topic/1536814-gpu-cable-bend/#findComment-16175386
