Nvflash help
Go to solution Solved by BiotechBen,
Once again, and as always, I experienced PEBKAC and ID10T errors.
I was doing nvflash instead of nvflash64
EDIT:
Nvflash working, but card is still giving undead vibes. It's giving "customer states" energy.
Howdy, looking at reflashing a card but have hit a road bump that I don't understand why is happening.
(Context)
 reflashing a card I got cheap as it was deemed to be "not working correctly" and can verify that no display out is the case. Windows recognizes it as a 1080 (Happy) but that something is very wrong with it(sad).
(Solution)
Reflash BIOS on card, think it has a mining bios on it/corrupted BIOS
(Problem)
Using this guide (so far the easiest to follow):
https://www.overclock.net/threads/easy-nvflash-guide-with-pictures-for-gtx-970-980.1523391/
I get to the identify flash stage and get nothing but cmd prompt errors
-Cmd print is in admin
-Following every step exactly as it is shown
-yes it is a picture instead of a screenshot, system stability ATM is: rough.
https://linustechtips.com/topic/1536266-nvflash-help/
