I run a 4 monitor setup and have done for many years.  A little over 12 months ago I upgraded my PC to an i5 12400F on an Asus Prime H610M-K D4 mainboard with 32GB of Corsair DDR4-3200, a 1TB WD Black SN770 M2 boot  drive and a MSI GTX 1660 Super 6GB video card.  I'm running 4x AOC 24inch monitors in a 2x2 grid.  My last PC had a GTX 1060 TI which had 3 x HDMI port and 1 x DVI.  This new video card has 3 x display port and 1 x HDMI.  The issue I have is the display port connections in the card are VERY finiky.  If one of my wife's cats bump the cable the monitor will stop working.I never have issues with the HDMI port only the display ports.  Once 1 goes off it takes ages to get them all working again because as I fix one a different one will stop working.  Has anyone else had similar issues, and if so did you find a resolution?
https://linustechtips.com/topic/1536134-problems-with-multiple-monitors/
