iCUE Issues w/Windows 11 Can't Uninstall iCUE
Solved by Adept_Austin,
QuoteWhen I go to This PC>Local Disk (C)> Program Files there is a Corsair Folder, I can open it and it shows iCUE5 with associated files. I tried to delete it and a dialog box pops up and says 'Folder In Use" 'The action can't be completed because the folder or a file in it is open in another program".
Have you tried opening task manager and force stopping iCUE? I'd try that and then try this step again. Let me know if this works or not.
