hello, im new here ..and i need some help connecting a LCD display...so..
i bought a LCD panel kit manufactured by asrock and it comes with a edp cable connection... unfortunately incompatible with my motherboard... the question is... can i connect through a adapter or something else? (i googled already and i found some boards but i am not sure ..)thank you
https://linustechtips.com/topic/1535421-connectivity-help/
6 hours ago, veno said:
bump?
well what board? what connectors does it have?, what gpu do you have, what motherboard do you have?.
what is it you want to connect through an adapter? USB? HDMI? DP? SATA?.....
we need to know what you are trying to connect with what to help...
https://linustechtips.com/topic/1535421-connectivity-help/#findComment-16168918
