Budget (including currency): 1500-1700£
Country: uk
Games, programs or workloads that it will be used for: just about any game, adobe, CAD software and any other design software
Other details
Like to play at 4k for games with good graphics smoothly, 1440p for most of the games. Preference AMD gpu and cpu.
I'm posting here to get any help with components compatibility or any suggestions to improve budget or better performance.
I did a parts list of which i think looks good and has good performance
here is my part picker list
PCPartPicker Part List
https://linustechtips.com/topic/1534865-new-build-help/
Give up the A-RGB fans in favor of a 7900X.
Is the 970 Evo drive already owned? If not get 2 Crucial P5 Plus.
The AIO has two fans. The case has 2 stock fans. No need for more.
CPU: AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor (£397.97 @ Amazon UK)
CPU Cooler: be quiet! Pure Loop 2 FX Liquid CPU Cooler (£110.99 @ MoreCoCo)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard (£177.75 @ NeoComputers)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory (£95.55 @ Amazon UK)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£103.99 @ Amazon UK)
Video Card: Sapphire 21330-01-20G Radeon RX 7800 XT 16 GB Video Card (£526.98 @ Overclockers.co.uk)
Case: Corsair 4000D Airflow ATX Mid Tower Case (£79.98 @ Scan.co.uk)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£99.95 @ AWD-IT)
Total: £1697.15
Generated by PCPartPicker 2023-10-08 02:45 BST+0100
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162158
33 minutes ago, brob said:
7900X
Depends on what OP's "CAD" app is. If they cant take more than 16 threads i would recommend 13700 or upcoming 14700 here instead. But OP wants AMD so...
Mild cost compression. If OP thinks of it no, i dont think you should put these nvme in RAID 0.
CPU: AMD Ryzen 9 7900 3.6 GHz 12-Core Processor  (£399.00 @ Computer Orbit)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  (£41.47 @ Amazon UK)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£169.00 @ Computer Orbit)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£112.27 @ Amazon UK)
Video Card: XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card  (£508.00 @ Amazon UK)
Case: Phanteks Eclipse G300A (3 Fan) ATX Mid Tower Case  (£65.00 @ Computer Orbit)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£104.99 @ AWD-IT)
Total: £1607.71
Generated by PCPartPicker 2023-10-08 04:02 BST+0100
Although, if OP stack 1800 GBP instead, we would get 7900XT which would be a nice bump in VRAM.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162194
32 minutes ago, brob said:
Yikes 😱 why would anyone contemplate RAID 0?
Layman when they realize that big numbers in tech doesnt matter every time:
AALIYAH_WROTE_JAY_AN_APOLOGY_LETTER%F0%9F%93%83__MARK_WANT_DESIREE_AND_HANNAH!%F0%9F%98%B1_4-32_screenshot_(1).jpg
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162215
Total: £1607.71
Thanks for your help
but why shouldn't i put them in raid 0?
to me the 2 nvme make it 4Tb
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162562
Total: £1697.15
thanks for your help
What is the difference between the 7700x and the 7900x ?
does the extra 4 cores make much of a difference for my use ?
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162567
An error on 1 of the drives loses all data on both drives. If you want 4TB, buy a 4TB drive
7900X has slightly higher clocks. Plus the added cores can be useful in highly threaded work like CPU renders.
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162658
This. The theoretical IOPS gain wont matter unless if you do storage intensive data processing where that kind of stat would matter.
Thats why i say to specify.
State your "CAD" app. But for what it is, Adobe shit thread scaling and Quick Sync Video really opens the door for Intel being better bet.
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162671
The main ones are CLO3D, archiCAD
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162988
6 minutes ago, Qwerty. said:
Can i use one nvme and a ssd would that have the same problem?
I wont recommend a different model of drives of any type to put under any RAID besides Raid Z and proprietary unRAID. And besides, your plan of Nvme and SATA raid wont work, it needs to work on same protocol to avoid problems.
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16162996
3 hours ago, brob said:
ALL RAID 0 arrays have the same behavior. It's in the nature of how RAID 0 works.
So i should get one 4TB nvme or are there any other solution to avoid RAID 0?
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16163189
You can get 2x2TB if you want. Just having 2 drives is not RAID 0. One has to explicitly create a RAID array. Otherwise the drives are independent.
https://linustechtips.com/topic/1534865-new-build-help/#findComment-16163304
