Kernel Power Event ID 41 freeze/crash using Firefox
Vampurrr
Go to solution Solved by PhantomWolfNL,
Hey i had the same problem with my build afther few weeks i found the problem for myself the fault lay in the power i turnd of the setting that the pc fasts boot and since then i dont have a problem anymore
聽sorry its in dutch but hope it wil help u a bit
Hi there,
A few months ago I recently built my PC and it's been running perfectly the entire time, except until the last two weeks.
For some reason twice in the last two weeks I've had my PC seem to crash/shut down, and it has only happened while watching a YouTube video on Firefox. I've never had it happen any other time. I've been able to game with intense games, such as Cyberpunk on Ultra with Ray Tracing for 5 hours+, and no crash. I've checked my drivers for my GPU, OS and peripherals, and everything is up to date.
The crash happened on a full-screen video. The audio went weird for a couple second, froze, then the computer reset.
The second time today, the audio went weird again, and then it stayed frozen on the YouTube Video. I ended up having to hold down the power button to shut off the computer.
This is the event data:
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
Checkpoint 16
ConnectedStandbyInProgress false
SystemSleepTransitionsToOn 2
CsEntryScenarioInstanceId 6
BugcheckInfoFromEFI false
CheckpointStatus 0
CsEntryScenarioInstanceIdV2 6
LongPowerButtonPressDetected false
LidReliability false
InputSuppressionState 0
PowerButtonSuppressionState 0
LidState 3
Any help would be appreciated, thank you 馃檪
My specs are: Windows 11, GPU Intel Arc A770, CPU Ryzen 9 7900X, 32GB DDR5, Asus ROG STRIX B650E-F, Corsair RMe Series RM1000e 1000W 80+ Gold
Thanks for that!
I turned off the fast start-up.
Fingers crossed that was the issue 馃檪
hey did my solution fixd it ?
i just build a new pc got the same problem again XD
