Budget (including currency): preferably under $1500
Country: USA
Games, programs or workloads that it will be used for: LoL, idk, I want to get into more games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  need keyboard monitor and mouse, I want an upgrade from my Mac (😮‍💨) but don’t want to spend a fortune but also something decently nice
https://linustechtips.com/topic/1533484-help-for-noob-pc-build/
Country: USA
Good balanced build, good gaming performance and efficiency.
https://pcpartpicker.com/list/hbkkXk
https://linustechtips.com/topic/1533484-help-for-noob-pc-build/#findComment-16151710
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($329.00 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($124.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($96.99 @ Newegg)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($97.99 @ Adorama)
Video Card: Sapphire 21330-01-20G Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ Newegg)
Case: BitFenix NOVA MESH SE TG ATX Mid Tower Case  ($54.90 @ Amazon)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Monitor: ASRock PG27FF1A 27.0" 1920 x 1080 165 Hz Monitor  ($129.99 @ Newegg)
Keyboard: HP HyperX Alloy Origins RGB Wired Gaming Keyboard  ($69.00 @ HP)
Mouse: HP HyperX Pulsefire Haste Wired Optical Mouse  ($39.99 @ Amazon)
Total: $1542.83
Generated by PCPartPicker 2023-09-29 00:25 EDT-0400
You can compress to a 7700XT or 6700XT if you want to get this to the sub 1500$ gaming system. But beyond that this should go hard for 1080p144.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1533484-help-for-noob-pc-build/#findComment-16151796
