1 hour ago, Hinjima said:
Remove the Cha_FAN so you get a better grip on the CPU FAN cable and pull it straight up while doing very slight wiggles.
exactly like @Hinjima says. Don't be afraid to exert a bit of force while wiggling the cables. The whole point is they're hard to remove.
https://linustechtips.com/topic/1531709-cpu-wire-wont-come-out/#findComment-16138989
Yeah but uh my issue is I pulled so hard I gave my self a blister from friction burns
https://linustechtips.com/topic/1531709-cpu-wire-wont-come-out/#findComment-16139306
