Budget (including currency): up to 1,000 usd
Country: U.S
Games, programs or workloads that it will be used for: Gaming pc including games like warzone,valorant etc. Also for Homework and coding/programing.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I prefer a ryzen 7 5800x but also looking for best option to fit my budget
https://linustechtips.com/topic/1530819-building-my-first-pc/
Hello, welcome to the forums.
Is your budget just for the PC, or does it need to include any peripherals like a monitor as well?
What resolution and refresh rate do you want to game at?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1530819-building-my-first-pc/#findComment-16132017
if i could end up getting a monitor also with my budget then yes i would like too, also i dont really know much about resolution and refresh rate so if you can recommend something i would appreciate it
https://linustechtips.com/topic/1530819-building-my-first-pc/#findComment-16132128
In that budget range I pretty much can only recommend 1080p144Hz unless if this PC is going to be a doorstop solution.
Quick upgrade time (Just CPU and GPU, replace cooler while you're at it and add more storage if need be):
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($219.99 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($124.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($96.99 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($49.99 @ Amazon)
Video Card: Sapphire PULSE Radeon RX 6700 10 GB Video Card  ($279.99 @ Amazon)
Case: Asus Prime AP201 MicroATX Mini Tower Case  ($69.98 @ Amazon)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Monitor: AOC C24G1A 23.6" 1920 x 1080 165 Hz Curved Monitor  ($119.99 @ Amazon)
Total: $1061.91
Generated by PCPartPicker 2023-09-10 21:39 EDT-0400
Slower upgrade time (youll need to replace the whole CPU platform and PSU):
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($145.15 @ Amazon)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard  ($74.98 @ Amazon)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($47.97 @ Amazon)
Video Card: Sapphire PULSE Radeon RX 7700 XT 12 GB Video Card  ($449.99 @ Newegg)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($68.68 @ Amazon)
Total: $1026.73
Generated by PCPartPicker 2023-09-10 21:48 EDT-0400
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1530819-building-my-first-pc/#findComment-16132246
