I've been trying to learn how to use curl and it works for the most part when I use a command like this (I'm using Windows' cmd)
curl --upload-file Test.txt https://x/
but I want to see the progress it takes to upload, i've tried with bigger files that take ~20 secs to upload and I'd like to see the progress and not just a frozen CMD terminal
curl --progress-bar --upload-file Test.mp4 https://x/
I figured adding --progress-bar would give me a progress bar but it doesn't, it has the same exact result. I found this on the internet, people have to put "| cat" at the end for it to work on linux, I can't find any for windows but Ia ssume "|type" worked the same way, and it shows the progress! But i think it messes with the file, because it would give me an error when it reaches 100% "url: (23) Failed writing body" this is the command i used
curl --progress-bar --upload-file Test.mp4 https://x/ | type
I presume the pre-installed curl on windows is a bit different, but I presume I can still do what I want, could someone help me out? Thanks!
https://linustechtips.com/topic/1530543-help-using-curl/
Are you using PowerShell? Because "curl" in PowerShell is actually an alias for Microsoft's "Invoke-WebRequest" command. So you'll have to look up which arguments that one takes.
If you want actual curl, I'd use WSL instead, then you should be able to use cat etc.
https://linustechtips.com/topic/1530543-help-using-curl/#findComment-16130116
Oh my bad I don't think i specified what I was using, I'm using "command prompt" i presume the curl using command prompt is the real one?
https://linustechtips.com/topic/1530543-help-using-curl/#findComment-16130121
It should be. To make sure type "curl.exe" instead. The problem is likely "type", as you said. It probably cuts off the stream before the upload is completely finished.
I'd try using something like Cygwin, which also contains cat, or the WSL2 that's built into Windows.
https://linustechtips.com/topic/1530543-help-using-curl/#findComment-16130129
