So I want to buy a laptop the asus tuf FX707Z-CHX044W-24-W11 because its in my budget ill put a pic of the laptop specs as a .png
but i have a problem with it due to it being a low budget laptop the battery is not the ideal type for me the battery is
  56WHrs, 4S1P, 4-cell Li-ion
 but i want a 90WHs, 4cell battery i just need someone to tell me if i get a battery for a differant model but the same type of laptop for example the Asus TUF F17 FX707Z-MKH085W-32-W11 which has the battery that i want can i put it in my laptop? i found a battery that supports most tuf but doesnt support my exact  model anything can help me somehow or explain something to me
https://linustechtips.com/topic/1529625-battery-question/
